Hi
I wanted to know how I can check the AC waveform on the O-scope. First thing I would need to do is set the O-scope's mode to AC waveform. Do I need to use a series resistor to limit the current, or does the O-scope have its own built-in automatic system to limit the current? If it has some automatic mechanism then that would mean I can directly connect the O-scope with the main. Any other suggestion or advice? Please guide me.
Thanks.
Regards
PG
Thanks.
Regards
PG
