Oscilloscope Advice Please
Discussion in 'General Electronics Chat' started by RodneyB, Jan 3, 2015.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    650
    14
    I have the opportunity to get an oscilloscope. As this is my first I an not sure I am getting the right thing.
    below are the details. I have read some mixed reviews which I will bring up with the supplier. I however want to know if this is a suitable oscilloscope for someone never having used one and if any limitations what are they.
    Specifications
    Hantek PC Based USB Digital Oscilloscope 6022BE
    1). Cost-effectiveness, 20MHz bandwidth 2CH scope,
    2).48MSa/s sample rate
    Hantek PC Based USB Digital Storage Oscilloscope 6022BE with 20Mhz Bandwidth
    Features:
    • USBXITM standard interface, convenient insert USBXITM case, the combination of instruments
    • USB2.0 port work with pc.
    • More suitable for notebook computer, production line maintenance adjustment, easy to use on a business trip.
    • Small size (mm):200(L)x100(W)x35(H)
    Technical Index:
    Channel
    bandwidth
    20MHz
    Single bandwidth
    DC to 20MHz
    real-time sampling rate-Max
    48MS/s
    Storage depth
    1M
    vertical resolution
    8Bit
    impedance
    1MΩ 25pF
    Coupling
    DC
    Voltage range
    20mV-5V, 8Steps
    Vertical Accuracy
    ±3%
    range
    1ns-5000s, 39 Steps
    The vertical position can be adjusted
    yes
    Input protection
    Diode
    X-Y
    yes
    Horizontal
    automatic, standard, single
    trigger slope
    Trigger level can be adjusted
    yes
    TRIGGER SOURCE
    CH1, CH2,
    Pre-trigger
    0-100%
    Sampling rate choice
    yes
    Fai line shows
    HP/line, brightness to adjust.
    network
    On/off
    Cursor measurement
    yes
    arithmetic
    Fast Fourier transform, reverse, add, subtract, multiply and divide.
    Cursor shows
    Frequency and voltage
    Accesories
    S/W CD, probes, manual, USB cord
    Software support: Windows 7, Windows NT, Windows 2000, Windows XP ,VISTA
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    PC based USB 'scopes are handy for general purpose and portability, the one shown seems as if it is a 8 channel, unless i found the wrong one?
    If you don' t really need this many, look at the Syscomp.
    Max.
    (I see it is the 2ch in your OP)
    RodneyB likes this.
  3. Dr.killjoy
    Apr 28, 2013
    1,209
    158
    I wouldn't waste money on that style of scope .. I would look into buying a used analog scope or buy a new digital scope..
  4. paulktreg
    Distinguished Member
    Jun 2, 2008
    624
    125
    If you go for a PC based USB scope then definately use it on a laptop as advised.
    I had one of the USB Hanteks, can't remember the model, but I found it great as a general purpose scope and particularly suited to audio frequencies. I made the mistake of using it on my desktop PC which was a mistake because the zero volt rail is connected to mains earth and I connected the scope probe ground to a high current (100A) 12V rail and the scope fizzed and smoked.
    I now use a Fluke Scopemeter via a USB optical link. Far safer!
  5. cmartinez
    Jan 17, 2007
    3,698
    2,788
    I own two hanteks, and I'm quite pleased with them, considering their price-to-performance ratio... although I know that most veterans in this forum will disagree with me...
    But you didn't mention the key to all the specs you gave, and I mean the "P" word... How much are you getting it for?
    I bet you even the hardiest analog scope fanatics in this forum might like to have one of those... if the price is right...
  6. RodneyB
    Apr 28, 2012
    650
    14
    The cost of the scope is US$60.00 Then US$11 Bank charges US$45.00 DHL and US$120.00 duty and Zimbabwe customs and clearing
  7. cmartinez
    Jan 17, 2007
    3,698
    2,788
    $60 dlls is fine for the scope... but considering how much it costs to get it where you are, I'd seriously consider getting a better one. That kind of scope brand new should cost a little more than $70 dlls. If the total amount adds up to $236.00 dlls, perhaps if you were to spend a total of $300 dlls you will end up with a much better one. I suggest you check some more on Amazon and other suppliers.
  8. RodneyB
    Apr 28, 2012
    650
    14
    Amazon wont deliver to Zimbabwe sadly. and the more the equipment costs the various duties etc. rise accordingly
  9. cmartinez
    Jan 17, 2007
    3,698
    2,788
    That's sad indeed... I remember a time in Mexico, back in the 60's and 70's when you couldn't get anything imported, and locally made electric and electronic products were lousy and expensive... it was very frustrating...
    Would having the scope sent to South Africa to an acquaintance of yours be a possibility? Maybe he or she could send it to you, or later deliver it when he or she has the chance....
    RodneyB likes this.
  10. spark8217
    Aug 29, 2011
    64
    Buy a digital scope or a used analogue with 100 MHz bandwidth with at least two channels or more if possible .you will only replace it with a better model at a later date ! ...
  11. Dr.killjoy
    Apr 28, 2013
    1,209
    158
    What about buying one on
    ebay ???
  12. RodneyB
    Apr 28, 2012
    650
    14
    I look at all the amazing things on Amazon and eBay and as soon as it gets to freight and duty into Zimbabwe Things become so bogged down in bureaucratic red tape they wont even ship to us.
  13. cmartinez
    Jan 17, 2007
    3,698
    2,788
    It must be very frustrating for you... have you considered shipping it to South Africa like I suggested?
  14. RodneyB
    Apr 28, 2012
    650
    14
    Yes I get all or at least 90% of my components from South Africa. I will look into it and see if Amazon and ebay would work there then onto Zimbabwe
