Oscilliscopes
Discussion in 'Homework Help' started by vineo76, Dec 13, 2004.
  1. vineo76
    Dec 6, 2004
    5
    I have found out how to measure current through a resistor, but I wonder why the current measures are starting to get way off when the resistance is at about lets say 470ohms. I wonder why the current can't be measured at a certain number of resistance. Does anyone know?
  2. pebe
    Oct 11, 2004
    628
    You don't say how you are measuring the current. Is it by measuring the voltage across the resistor? If so. the current will be proportional to the measured voltage, whatever the resistance value.
    Can you provide a bit more detail?
  3. krgoutham
    Member
    Dec 8, 2004
    22
    Hi
    I guess u are the same guy that asked the ammeter question earlier. Did you connect it in series to calculate the amount of current flow through ur circuit??????
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If the current gets wierd as the resistor value decreases, your source is probably not able to supply the necessary current.
Related Forum Posts:
  1. vineo76
    1,587
