Hi i try to simulate this circuit by using pspice but it did not work so can some one help me what is the problem
thanks
thanks
What means "did not work"?Hi i try to simulate this circuit by using pspice but it did not work so can some one help me what is the problem
thanks
the out put should be square wave and frequency about 30khzWhat means "did not work"?
As a most import aspect in simulating a circuit - one should approximately know in advance what the result should be.
In case you know that - it would be wise to inform us about your expectations.
What do you want? An oscillator (with sinusoidal output) or a multivibtator (relaxation oscillator)? What frequency? And what do you get from the simulator? Nothing? You see - a substantial answer can be expected only in case of a good and detailed question with all necessary information.
Apparently most oscillator types are kicked off by resistor noise or some imbalance due to tolerances on individual components.Hi i try to simulate this circuit by using pspice but it did not work so can some one help me what is the problem
thanks
This is typically not necessary in a hysteretic oscillator, which this.Apparently most oscillator types are kicked off by resistor noise or some imbalance due to tolerances on individual components.
Usually - in a simulation; you have to give it a prod to get it going. Probably a voltage source programmed for a single narrow pulse.
Yes - that´s correct. R6 must be changed to provide positive feedback.I believe that r6 might be meant to feed hysteresis back positive amp input and not connect to the positive supply.
Yes? I never did!Hmm I sometimes see this kind of resistor in a wien bridge oscillator . (output to positive rail with a 10k)
R4 provides the positive feedback. R6 is the pullup for the open collector output of the LM139.Yes - that´s correct. R6 must be changed to provide positive feedback.
Oh yes - sorry for my mistake. I overlooked the positive feedback path (perhaps because it is shown at the bottom of the drawing).R4 provides the positive feedback. R6 is the pullup for the open collector output of the LM139.
by Duane Benson
by Duane Benson
by Duane Benson
by Jake Hertz
