oscillator
Discussion in 'Homework Help' started by betyson, Mar 7, 2013.
  1. betyson
    Mar 7, 2013
    I need to design an RC oscillator ckt with Capacitance value b/w range 23pF-26pF (i employ the capacitor to measure change in humidity)..the output of which is to be connected to FtoV converter(lm 311)...(for which i need extremely stable output)....
    Can i get suggestions on circuit design...
  2. favner85
    Nov 4, 2012
    8
    What output waveform you need for the oscillator? What's the frequency range?
  3. betyson
    Mar 7, 2013
    Any waveform will do..the frequency range should preferably be within several kilohertz...because I need lower frequencies...!
  4. ramancini8
    Member
    Jul 18, 2012
    447
    119
    It will be extremely hard to obtain an RC osc. using 23-26 pF unless the osc. frequency is in the MHz.
