Oscillator test
Discussion in 'General Electronics Chat' started by Martin Nikovski, Nov 16, 2015.
  1. Martin Nikovski
    Nov 16, 2015
    Hello! I am really happy to find this forum and I hope that we can all benefit from our interaction here.
    I have the following question:
    Say I have an oscillator but I have only VDD and GND pins working. This way, I can apply voltage to it, but I can't get an output signal (at least not via a wire)... I have to propose a way to test whether the oscillator is working properly (creating an oscillating signal) or it's defective. So, it has to be some "remote" wireless method. I would appreciate any ideas. Thank you in advance!
    Best regards
  2. DickCappels
    Aug 21, 2008
    2,774
    671
    It depends upon the oscillator type, its physical construction and the oscillation frequency.
    If there is no internal bypass, put a few ohms between the power supply bypass capacitor and the power input of the oscillator and try to find the oscillator with a spectrum analyzer connected to the power input. If you know the frequency of the oscillator, try to find it with a radio receiver.
    Martin Nikovski likes this.
  3. Martin Nikovski
    Nov 16, 2015
    Thank you for the suggestion! I forgot to mention that the whole oscillator is in a sealed housing so I don't have access to the circuit itself.
  4. DickCappels
    Aug 21, 2008
    2,774
    671
    What else can you say about the oscillator? Manufacturer/part number...?
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    if its one olf those crystal can oscilators with the frequency marked, just use an apropriate reciever to listen for the carrier. such as a 10 mhz oscilator, use a short wave reciever tuned around 10 mhz to listen for it.
  6. Alec_t
    Sep 17, 2013
    5,977
    1,136
    Is this a homework question/project?
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,456
    792
    The metal can oscillators that fit a regular 0.3" IC socket, sometimes have an enable pin.
    The datasheet and carful look at the part number may be the only solution.
