oscillator simulation
Discussion in 'The Projects Forum' started by kahafeez, Dec 21, 2008.
  1. kahafeez
    Thread Starter Active Member
    Dec 2, 2008
    150
    hi i need to simulate a 200KHz sine wave oscillator.... a wein bridge one.... which software do i need to simulate it???? i've tried a few bt they dont work.... i've tried Proteus, Multisim, EWB...
  2. kahafeez
    Dec 2, 2008
    150
    this is a try at circuit maker 2000 or version 6.... this is what i get....
    • osc.zip
      File size:
      2.4 KB
      36
  3. kahafeez
    Dec 2, 2008
    150
    i used the figure 3 ckt in my lab for a test and the result was great.... a pure sine wave of abt 229KHz with abt 15Vpp....
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    In the Circuitmaker version "osc.ckt", you did not have power supplied to the opamp.
    The +V gets connected to the top pin, the -v to the bottom pin.
    I suggest +10v and -10v.
  5. flat5
    Nov 13, 2008
    403
    17
    May I ask, what improvement do the extra parts in fig. 4 provide?
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    They gently clamp the max output swing of the opamp so that its output does not slam into the power supply rails and produce a badly clipped sine-wave like the first circuit does.
