oscillator - metal detector
Discussion in 'General Electronics Chat' started by bujak18, Dec 4, 2008.
  1. bujak18
    Thread Starter Active Member
    Nov 12, 2008
    49
    how could an oscillator be used as a metal detector?
  2. mik3
    Feb 4, 2008
    4,846
    63
    If it is a sine wave oscillator you can drive a coil with it and when a piece of metal (one that induced currents, due to changing magnetic field, can be created inside) comes close to the coil, the current through the coil will decrease.
  3. bujak18
    Nov 12, 2008
    49
    could you please clarify this?
  4. mik3
    Feb 4, 2008
    4,846
    63
    current through inductor(rms)=Vacross inductor(rms)/(2*pi*f*L)
    f=signal frequency
    L=inductance
    As the metal object gets closer to the coil its inductance increases and thus the current decreases (see equation above). Regarding the inductance, you have to study magnetics to see how it is affected by the material parameters, number of turns of the coil, etc.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  6. Bernard
    Aug 7, 2008
    4,240
    414
    In short: a metal detector consists of two oscillators,one the search coil[part of an oscillator] and a referance oscillator ,the two frequences are non linearly mixed.Oscillators are adjusted for O beat . When a metalic object comes near the search coil ,its inductance is changed causing a change in frequency,the beat note is herd as a tone.
  7. Ron H
    Apr 14, 2005
    7,050
    657
    Commercially available BFO metal detectors are not common. More common are VLF (very low frequency) and PI (pulse induction) types.
    Here is a discussion of how they work. I haven't read it carefully, so I can't vouch for its accuracy.
  8. Beduin
    Member
    May 20, 2009
    16
    lol... I actually in the middle - well, the end- of a project where me and my group have to make a metal detector , using one coil.
    I can see it is an old thread, but hey..would love to share what I have ( have to hand in on may 26th09).
  9. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  10. RiJoRI
    Aug 15, 2007
    536
    26
    This is WEERD! I've noticed that questions about a certain subject come up shortly after an article on said subject has shown up in Nuts&Volts! And from the questions, it does not appear that the questioner has read the article.
    Anyway, yep, there was a two-issue article on metal detecting in the March & April 2009 issues.
    --Rich.
  11. Ron H
    Apr 14, 2005
    7,050
    657
    We'll look forward to seeing your design and a report on its performance.:)
  12. Beduin
    Member
    May 20, 2009
    16
    yeah? am thinking of posting the whole thing in the project forum. :D
    edit: I think I will do it
