Oscillator circuit
Discussion in 'Homework Help' started by xxxyyyba, Nov 21, 2015.
  1. xxxyyyba
    Aug 7, 2012
    249
    Hello. Here is my task:
    Oscillator circuit is shown.
    a) Calculate frequency of oscillations,
    b) Calculate minimum value R1 for which circuit still oscillates,
    c) Calculate amplitude of voltage VB, for which voltage VA start cuting off
    Vz=6.3V, R1=100K, R2=120K, R3=470, R4=2R6=10K, C1=C2=100nF, Vd=0.7V, R4=R5.
    I completed task a) and task b)
    I got f_oscillations=232.7Hz and R1_min=250k.
    I don't know how to solve task c)
    Any idea?
    Thanks in advance.
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Well, find Vb/Va = gain for Fo and do you know the "cutting off" voltage for this simple diode limiter?
    VA start cutting off = "cutting_off voltage" * gain.
  3. Jony130
    Feb 17, 2009
    3,990
    1,115
    Also notice that if R1 is change from 100k to 250k the Fo will also changes.
  4. xxxyyyba
    Aug 7, 2012
    249
    <br />
-I_1-I_2+I_3+I_4=0,<br />
-\frac{V_B}{R_1}-\frac{V_A-V_X}{R_2}+\frac{V_X-V_B}{\frac{1}{sC_2}}+\frac{V_X}{R_3}=0,<br />
\frac{V_B}{R_1}=-\frac{V_X}{\frac{1}{sC_1}}=-sC_1V_X\Rightarrow V_x=-\frac{V_B}{R_1C_1s},<br />
V_X(\frac{1}{R_2}+sC_2+\frac{1}{R_3})-V_B(\frac{1}{R_1}+sC_2)=\frac{V_A}{R_2},<br />
-\frac{V_B}{R_1C_1s}(\frac{1}{R_2}+sC_2+\frac{1}{R_3})-V_B(\frac{1}{R_1}+sC_2)=\frac{V_A}{R_2},<br />
\frac{V_B}{R_1C_1s}(\frac{1}{R_2}+sC_2+\frac{1}{R_3})+V_B(\frac{1}{R_1}+sC_2)=-\frac{V_A}{R_2}
    And we can find now VB/VA. Is it ok?
  5. Jony130
    Feb 17, 2009
    3,990
    1,115
    Do you manage to find the gain ??
    I got this result :
    \frac{Vb}{Va} = \frac{C1*R1}{(C1+C2)*R2)} = \frac{25}{24} = 1.041\frac{V}{V}
    And Fo is around 147Hz
    Also as a side note I immediately recognized this circuit with OP2 alone, as is used in guitar effects
    http://www.muzique.com/news/wahantiwah-mod/
  6. xxxyyyba
    Aug 7, 2012
    249
    I definitely made mistake somewhere. Your gain Vb/Va doesn't depend on s...
  7. Jony130
    Feb 17, 2009
    3,990
    1,115
    But the gain is depend on s. My formula is a valid only at Fo. And if you solve for Vb(s)/Va(s) you already have a voltage gain expression.
    All you need is to find gain at Fo frequency.
  8. xxxyyyba
    Aug 7, 2012
    249
    Jony30,
    I got same result as you in post #5 using analysis in post #4.
    I got w0=sqrt((R2+R3)/(R1*R2*R3*C1*C2))=924.3361 rad/s
  9. Jony130
    Feb 17, 2009
    3,990
    1,115
    Good for you.
    And the transfer function (if i do not make any error) in standard form is :
    \frac{V_b}{V_a} =-\frac{ \frac{1}{C2 R2}s } { s^2+\frac{(C1+C2)}{C1C2R1}s\frac{R2+R3}{C1C2R1R2R3}[\tex]
    T(s) = (a1*s)/(s^2 + ωo/Q + ωo^2)
    And the gain at Fo is
    Av =(a1*Q)/ωo = (C1 R1)/((C1 + C2) R2)
