When the charger was tested on the other iPad, was the voltage measurement gadget in circuit, and what reading did you get?Thank you for your reply.
The charger is tested on another ipad and works good.
The part with "drawing too much current" is interesting. Could you please give me more details? Should I go to the ipad's mainboard to check for something? What can cause this power draw? ICs or caps?
I don't know that the battery can cause this. Suggesting any possible cause, based on present information, can be only wild guesses.I will check this. Thank you very much. As a side topic: what could cause this intermittent voltage up/down, besides the battery?
Most likely a capacitor causing an over current condition. It goes into over current and shuts down. When it shuts down the over current goes away and it tries to turn on again. Goes into over current ...Hello
I have a device that stopped working suddenly. Now the voltage required by it is not constant anymore. It is just 0V, 2V, 0V and so on, changing every second. Could anyone guide me into finding the cause of it?
Thank you!
by Jake Hertz
by Duane Benson
by Jake Hertz
by Jake Hertz
