Oscillating a voice coil
Discussion in 'Homework Help' started by lledezma, Dec 2, 2008.
  1. lledezma
    Dec 2, 2008
    What would be the best type of circuit to oscillate a voice coil at 100Hz operating with approximately 45mA. I have a supply of 3-3.5 VDC available. I am trying to vibrate the coil and believe that a square output would be best. I have looked at various circuits with the 555 timer, but are there better more efficient ones?
    Thank you very much in advance.
  2. KL7AJ
    Nov 4, 2008
    2,043
    292
    A 555 is a pretty efficient way to go. You might want to resonate the voice coil with a capacitor, which will greatly smooth out the tone. Not sure exactly what your application will be. (A loudspeaker actually has two main resonances...the mechanical one, and the electrical one. There's a great deal of interaction between them. But try putting a 10 uf capacitor across the coil for starters. If you want to get into a great deal of detail on this, I'll show you how to determine the free air resonance frequency of any speaker. :)
    eric
