orCAD PSpice model for micro and sensor
Discussion in 'Embedded Systems and Microcontrollers' started by Alex9, Oct 1, 2013.
  1. Alex9
    Sep 3, 2013
    10
    How to create the equivalent model of this diagram in the program?
      File size:
      13.4 KB
      37
  2. ErnieM
    Apr 24, 2011
    7,440
    1,627
    Is there some compelling reason to model a simple three terminal device, albeit one with a rather pronounced temperature coefficient?
  3. Alex9
    Sep 3, 2013
    10
    I didn't find model of these components on sites of vendors. I drew the equivalent circuit, but it measures the same tension. How to make a source controlled? The source replaces the sensor.[​IMG]
  4. Alex9
    Sep 3, 2013
    10
    I need to execute the following analysis types in this program:Bias Point Delay, DC Sweep,AC Sweep,Transient,Fourier Analysis,Parametric,Monte-Carlo,Sensitivity,Transfer Function,Worst-Case.It is necessary to clarify how my diagram works. Thank you.
  5. Alec_t
    Sep 17, 2013
    5,977
    1,136
    I'm not familiar with Orcad, but simulators generally provide controllable voltage and current sources as standard components.
