Orcad Model Editor
Discussion in 'Electronics Resources' started by Management, Apr 9, 2009.
  1. Management
    Thread Starter Active Member
    Sep 18, 2007
    Can I ask questions in this section about Model Editor? People here use it much?
    If so,
    Below are many similar questions on syntax for Model Editor. I tried not to be repetitive. I read the manual but it starts to get a little confusing. Thank you.
    I am trying to learn how to use Model Editor and I am getting a little confused. Below is what I have in model editor:
    .model GaN NMOS (LEVEL=3 VTO=-5.0 L=2u W=6.5m)
    Is this correct? I know the width seems a little huge. That is intentional. My MOSFET is suppose to be an N-channel Depletion Mode MOSFET, did I set that up correctly.
    Also, I wanted to look at a short channel device model. From what I understand a level III model is what that is suppose to be, correct? Did I label that correctly?
    How can I override values such as on resistance, off capacitance, gate-drain capacitance, drain-source capacitance, gate-source capacitance, and gm (that's transconductance correct? mS/mm?).
    Can I override DC breakdown voltage?
    I want to put in sheet resistance (Rsh?) as well as Idss.
    How should I put in mobility and sheet charge density?
    Again, I know this is a lot of the same/similar questions it's just that I am very new to this and I'm not sure what can actual get put in to override some level 3 parameters.
    Thanks in advance.
