OrCAD - Hierarchy
Discussion in 'General Electronics Chat' started by Lukas Park, Apr 29, 2014.
  1. Lukas Park
    Apr 27, 2014
    21
    Hey guys, Hello again.
    I've just disccussed with my collegues about the pros and cons of hierarchy in OrCAD tool.
    As our opinions,
    @Pros : The hierarchy ..
    - Reduces human error
    - Reduces circuit drawing time
    @Cons : The hierarchy ..
    - Makes debugging harder with printed PDF file
    Let me know if you have any ideas more??
    Thanks all read.
  2. ErnieM
    Apr 24, 2011
    7,434
    1,625
    As a clear well laid out schematic is the initiall cornerstone document of anything electronic I would say your single "con" overrules and pros.
    Not only debuggibng but anyone attempting to understand the circuit for any reason needs that schematic in a clear readily readable form. If going to multiple pages each page should cover a function (or entire functions).
    One can also make an argument for various versions of the schematic. Many components have multiple connection points that only appear once on a schematic, but have several "pads." Think of a TO-3 transistor: each collector screw needs a pad, so the schematic symbol needs two collector connections for the netlist to flow. Such tool artifacts get in the way of grasping simple details.
    Lukas Park likes this.
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,679
    1,295
    I haven't used OrCad since its DOS days, but that was a very good tool. I liked the hierarchy function because it enforced discipline. I usually do a block diagram before a large schematic anyway, so there is no net time penalty. The hierarchy function made sure that all of the required interconnects were there. That can be worth tens of K$ down the road, way worth a little printing hassle
    ak
