Orcad 9.2 pcb design....
Discussion in 'The Projects Forum' started by RRITESH KAKKAR, Mar 24, 2013.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    I learning orcad 9.2 capture then layout plus.....
    anyway i was reading tutorial after drawing and saving the schematic the tut. say to go tools>netlist but i don't find the tools option so, netlist can be done for layout plus....
    pls help me how to start i think this will be software
    thanks
  2. ErnieM
    Apr 24, 2011
    7,435
    1,625
    "Tools" is right on top of the main screen, the 5th menu choice.
    You need to first go to the project explorer and select something in or under the dot-dsn branch before you can create a netlist.
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    OK, its working fine the problem was missing .dsn while saving
  4. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Hi again,
    I am reading introduction to Orcad pcb layout tut.
    according to tutorial while placing component the symbol for Pspice and layout should be shown in place window but in my window no symbol are appearing on any component, why??
    thanks
  5. kubeek
    Sep 20, 2005
    4,687
    805
    You probably don´t have a pspice model and standard footprint associated.
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    How it can be possible with all component and how to have layout symbol in it?
  7. kubeek
    Sep 20, 2005
    4,687
    805
    Are those your own libraries or are you talking about the original ones, if there are some?
    By layout symbol you mean footprint for pcb? It could be that you´re looking into a wrong library..
    Also, when you place a schematic you can edit each part and assign the pcb footprint variable, using the name of footprints you find in c:\Cadence\SPB_16.5\share\pcb\pcb_lib\symbols\
    at least that is the way it is done in 16.5
  8. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Hi again,
    I have created the net list there are many option in window but i want layout only so, i have selected it then it ask for run ECO in layout what is this??
    and showing many error how to move forward by removing error??
  9. kubeek
    Sep 20, 2005
    4,687
    805
    I'm starting to loose faith in humanity. Can't you realize that asking "It gives me some errors, how do I correct them" makes no sense?
    How am I supposed to tell you what to do when I don't know what those errors are....:confused:
  10. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    The following 1 points have been identified as net connectivity change points from the last operation
    (17.40, 7.60)
    (17.50, 6.70)
    (17.50, 7.20)
    (17.60, 7.10)
    (17.70, 7.00)
    (17.80, 6.90)
    (17.90, 6.80)
    (12.40, 0.60)
    (11.00, 0.50)
    (10.80, 0.20)
    (13.50, 1.20)
    (12.90, 1.20)
    * Create Netlist
    Netlist Format: LAYOUT
    Design Name: C:\USERS\ABC\DOCUMENTS\PCB\MY1PCB.DSN
    ERROR [MNL0019] 'D7.1' is tied to nets 'N24848' and 'N16936'.
    .....................................................................................more
  11. kubeek
    Sep 20, 2005
    4,687
    805
    The first is things are just warnings that inform you on changes in the schematic after say moving a part. The second are kinda strange, because they say that pin 1 of D7 is connected to two different nets at the same time which I think should not be possible to achieve. You probably need to check the schematic to see what is going on. Can you post a screenshot?
  12. ErnieM
    Apr 24, 2011
    7,435
    1,625
    How many D7 are in the schematic?
  13. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    here is the schematic .doc to .dsn
    some changes are done in schematic but again error
  14. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I don't know what is the problem....??
    I have tested another small test circuit asking layout lib not found how to get it???
