Orange things with many pins on bus lines
jamus
Joined Feb 11, 2013
54
Can anyone explain to me what these orange things are and how they work? I often see them at the beginning and end of bus lines on various 1990s industrial electronics. Perhaps they are capacitors of some type?
Here is a picture I found on the internet. Orange things terminating a bus.
ErnieM
Joined Apr 24, 2011
8,377
Bus resistors, my guess too.
Oft with an odd number of pins: a 9 pin device would have 8 resistors, each connects to the 9th pin.
Used for a pull-up, down, or impeadance match useage,
AnalogKid
Joined Aug 1, 2013
11,056
What you have is a 4-slot VME J1 backplane. The small orange parts are ceramic and tantalum decoupling capacitors. The large orange parts are terminating impedance networks. For each address and data line and most control lines there are two resistors per line, 330 ohms to +5V and 470 ohms to GND. This sets up a Thevenin equivalent impedance of 194 ohms at 2.94V. Static current through the networks with no boards plugged in is around 1A.
Most of the signals are bussed to the same pin at each slot. The groups of jumpers between slots control the bus grant and interrupt acknowlege daisy-chain signals. The jumpers complete a bypass around a slot; you install the jumpers if the slot has no board installed. Other backplanes use mechanical or electronic means to bypass empty slots automatically, and active bus termination.
A full VME-64 compliant backplane is twice as tall and has another row of identical connectors, the J2 row, plus more terminators. There are not as many as for the J1 row because in J2 only the center column of pins has VME signals; the two outside rows are for user-defined I/O.
ak
THE_RB
Joined Feb 11, 2008
5,438
That photo is marked
- 2 - 272
which is a 2-pin resistor pack, with FOUR 2-pin independent resistors and 8 pins. 2k7.
Doesn't bus termination use 8 resistors to ground?
Tshuck's "9E" package is a 9pin bus 8-resistor pack type.
30,824
Sorry, I just posted an orange looking resistor pack, not the exact one used on the VME card bus. AnalogKid has a better explanation above in post #4.
