Orange and gray wire on a motor?
Discussion in 'General Electronics Chat' started by jayrare, Aug 27, 2007.
  1. jayrare
    Aug 14, 2007
    7
    I tore apart an old nonfunctioning cd player today to get at the motors. One of them have normal red and black wire, but the other one had orange and gray. Both motors' wires were connected to a little white thing which I'm thinking is just used to connect to the circuit board, but I'm not sure. I am planning on just cutting them off from the white thing, but just to make sure, are the orange and gray wires just used to set them apart from the other motor's wires, or is there something special going on?
  2. Distort10n
    Dec 25, 2006
    429
    Off the top of my head, I am not sure what the orange and grey wires would be.
    Grey may be neutral since it is a motor.
    Then again, is this a stepper motor?
  3. kender
    Jan 17, 2007
    263
    I was goind to suggest that you coul be facing a stepper motor too. If it's a stepper it's probably a bipolar stepper, and each winding has it's own pair or wires.
    If you have a digital camera, could you post a picture of the motor, wires and the rest of your CD player's internals?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If it's the main motor, it's not a stepper. The jerkiness of the action would not allow operation, plus it would not spin fast enough. The motor has to change speed as the head progreses across the surface. The two wires may be part of the speed sensing.
    At a guess, the white thing is a connector.
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Perhaps a photograph would be of help here?
    Dave
