OR GATE LATCH
Discussion in 'General Electronics Chat' started by pilko, Jan 25, 2009.
  1. pilko
    Thread Starter Senior Member
    Dec 8, 2008
    213
    20
    This simple latch works OK on my breadboard,but doesn't work on my simulator.Am I doing something wrong?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    You probably need to connect the unused inputs of your OR-gate to ground.
    hgmjr
  3. pilko
    Dec 8, 2008
    213
    20
    The unused inputs are connected to ground,and it works OK on the breadboard.I cannot get it to work on my Logic Lab simulator.I thought I may be performing an illegal operation.I havn't seen this application used anywhere.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    You drawing does not indicate that the unused inputs are tied to anything. That is why I replied as I did.
    If your simulated device has its unused inputs tied to ground then it should work.
    hgmjr
  5. Ron H
    Apr 14, 2005
    7,050
    657
    In real hardware, I suspect that the output will come up either high or low when power is switched on, depending on the internal circuitry. I'm not sure what simulator you are using, but unused inputs of behavioral gates in LTspice are automatically inactive, so grounding them wouldn't help..
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Please define the phrase "doesn't work." Is the simulator output always low? Does it follow the input? Is the o/p an analog representation of a Barry Manilow tune?
  7. pilko
    Dec 8, 2008
    213
    20
    I have attached the graph for both modes of operation.The breadboard version latches,the simulator vertion doesn't. Thanks for the prompt replies.
  8. pilko
    Dec 8, 2008
    213
    20
    I screwed up. Here is the correct diagram
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It works in my simulator, even using CMOS logic without having all of the unused inputs grounded. Perhaps you've found a bug in your simulator software.
  10. pilko
    Dec 8, 2008
    213
    20
    It's a USB interface device called Digi-bee+ with simulating software called Logic-Lab plus I have just written to them hoping they can help me
    Thanks for your help everyone
  11. pilko
    Dec 8, 2008
    213
    20
    If it was behaving like an AND gate,the output would not go high at all
  12. hgmjr
    Jan 28, 2005
    9,030
    214
    Pilko is correct. My goof.
    hgmjr
