OR Gate for 12 light circuit
Discussion in 'The Projects Forum' started by kpgraci, Jul 30, 2010.
  1. kpgraci
    Jul 30, 2010
    Hi all,
    Novice, I've built projects before, never designed one.
    I have sailboat with a light composed of two independant 12vdc white LEDs (I think they are leds) (L1 and L2 in attachment).
    I have a SPST switch S1 that should turn on both lights, and a SPST switch S2 that should turn on only L2.
    I propose to insert a diode D1 as shown to prevent L1 from turning on when S2 is closed.
    Will this work? Do I need anything else? :confused:
    For a 12VDC (car battery) what Diode would D1 need to be to handle the power?
    Thanks!
    kpg
    PS - I know this can be done with a DPDT switch and wiring only, but I need it to go through a fuse panel with only SPST switches.
  2. KMoffett
    Dec 19, 2007
    2,586
    234
    Yes, it will work. What is the wattage of L2. That will determine what diode will be needed.
    The two SPST switches could be replaced with one SPDT/Center-OFF switch.
    OOPS, missed the PS
    Ken
    kpgraci likes this.
  3. Bernard
    Aug 7, 2008
    4,248
    423
    If L1 & L2 are LED's, then do not forget to add current limiting resistors. Need L specs.
  4. windoze killa
    Feb 23, 2006
    605
    24
    I think the OP is only showing the LEDS as single unit when they are actually commercial lights already installed. He just wants to switch them differently.
