Way too much missing information, like the circuit the transistor is in. But, based solely on your information - no. Even a germanium transistor needs more voltage than that to become biased into conduction, again assuming you mean 150 mv on the base relative to the emitter.
For conduction to occur, some voltage must be present. The precise voltage will difffer device to device, so the significant condition is insuring that the B-E junction current is limited to a safe value.
Quiescent current is due to the nature of the circuit the transistor is in, and has to do with biasing. The B-E voltage only has to do with forward biasing. Current in the base is controlled by external devices.
Once in conduction, the current in the B-E junction is the control. More current in the base, more current in the collector circuit.
Terminology check - does OPT stand for OutPut Transistor? The prefered term is BJT for a transistor - Bipolar Junction Transistor. It would be more clear to refer to a BJT un the output stage of an amplifier.
ok say for example the driver transistor has a 2.2k emitter resistor, across the resistor the voltage reading is minimum 150mV. so, the Vbe of BJT is also 150mv. now, how to determine the quiescent current?
With Vbe = 150 mv, the transistor is not conducting. 150 mv across the emitter resistor means there is 68.2 microamps current through the resistor. A voltage across a resistor only measures the current.
This might be easier to figure if you can post up the schematic.
Qa,Qb,Q1 and Q2 Vbe are all 650mV
DC offset is +/-25 mV measured fro the ouput,
Vbe od Q3 and Q4 is 150mV
150 mV is also the measured voltage across 2.2 ohm emitter resistor. while VR2 is set to its minimum position.
When VR2 is adjusted to the midpoint position the reading is 300mV.
and the full adjustment reads about 550mV.
Now, can we say that the transistor is conducting with a quiescent current for as low as 68.2mA?
