Optrex Color LCD Display
Discussion in 'The Projects Forum' started by electronics wiz, Sep 10, 2007.
  1. electronics wiz
    Thread Starter Active Member
    Mar 15, 2007
    54
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    An RCA connector is just that. What kind of signal is the connector going to carry?
  3. electronics wiz
    Mar 15, 2007
    54
    The signal that will be carried is the same signal that comes from a TV.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The tv and the display are receivers, so the signals go to them.
    The LCD display has pixels turned on and off by digital logic levels. A tv signal is analog in nature. See this as a very brief description of the composite tv signal - http://electronics.howstuffworks.com/tv9.htm.
    You might want to look at Don Lancaster's TV Typewriter as one possible solution.
  5. electronics wiz
    Mar 15, 2007
    54
    Thanks for the response, but I still cant design the circuit myself,any ideas on what ICs to use? (It cant be a PIC)
  6. Art
    Distinguished Member
    Sep 10, 2007
    797
    61
    That LCD is an OEM module missing all the guts to drive it.
    What you are talking about is biulding a monitor and you only have the screen.
    It would take so much effort to design it would be silly to do it to make a single unit.
    You're looking at a circuit with many ICs not just a pic.
