Plz can u tell me what is optisolator....?
It is an LED and a Photo-transistor. When the LED is illuminated the photo-transistor goes from cutoff to saturation. When the LED is dark the photo-transistor returns to cutoff. The photo-transistor can be configured as a common emitter switch or as an emitter follower depending on weather you want the output to be inverting or non-inverting. The chief reason for using one is to provide isolation between the input circuit and the output circuit.Can you tell me what an optoisolator is please?
by Jake Hertz
by Duane Benson
by Jake Hertz
