Optoisolator circuit
Discussion in 'General Electronics Chat' started by picstudent, Nov 28, 2010.
  1. picstudent
    Thread Starter Active Member
    Feb 3, 2009
    76
    I am trying to make a circuit which I can use in my UPS project.
    I need to get a sine wave form centered around +2.5 volt using an opto coupler. The AC is to be isolated by the opto and this 0 to 5 volts varying DC which will be a dc isolated replica of the Line voltage will be used for tracking mains.
    I have tried a circuit in workbench and it is showing somewhat acceptable results.
    Is this idea workable?
    Thank you
    Roy
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You might wish to have a 60 Hz source that is not line dependent. A UPS is designed to supply power when the line power has shut down.
