Optoelectronics: Frequency dependant Quantum Efficiency of Si Photodiodes
Discussion in 'General Electronics Chat' started by gefeba, Oct 15, 2013.
  1. gefeba
    Oct 15, 2013
    Hi guys!
    I'm working with TIA photoreceivers and I've been encountering some troubles with the frequency response of my device when using Silicon Photodiodes.
    Using a modulated laser as input signal, my PRs transfer function decreases from 10 KHz on, and it could be explained easily if the Quantum Efficiency of the device is actually frequency dependant (at least for frequencies higher than 10 KHz, since before it seems constant), but it's something I can't find anywhere.
    Thanks in advance.
  2. wayneh
    Sep 9, 2010
    12,368
    3,224
    Could simply be the bandwidth is too low for your frequency. The photodiode should have specifications for bandwidth.
  3. gefeba
    Oct 15, 2013
    Thanks for your answer wayneh!
    That's the thing, sometimes (I'd say, most of the time) the datasheet only specifies the rise-time of the photodiode as sth I could use to calculate the bandwidth. In my case, the bandwidth of my photodiode (0.35/rise_time) would be sth around 10 MHz, not 10 KHz.
    On top of that, the drop of magnitude in the TF does not correspond to the equivalent drop in the phase that I'd expect due to a limited bandwidth (the drop in phase is around 10 MHz).
    Since it's a magnitude-related thing, everything points into the Quantum-Efficiency - responsivity direction...
  4. wayneh
    Sep 9, 2010
    12,368
    3,224
    You need somebody that knows something. Rules me out. :confused:
  5. w2aew
    Member
    Jan 3, 2012
    219
    64
  6. crutschow
    Mar 14, 2008
    13,472
    3,361
    Quantum frequency effects normally occur at very high frequencies. I suspect you have a circuit related problem. Post your circuit diagram.
