Optocouplers with microcontrollers
Discussion in 'The Projects Forum' started by newt, Jul 6, 2009.
  1. newt
    Jul 6, 2009
    I'm working on a project where I want to control 8 outlets with a microcontroller. The load on the outlets will be 110-120 VAC and up to 600 W or 6 A, and the control voltage will be 5V DC from the microcontroller. I believe optocouplers will work best. I've seen several in quad DIP packages which would be awesome, but I can't find one that will fit my load parameters. Does anyone know of any? Thanks in advance.
  2. eblc1388
    Nov 28, 2008
    1,542
    102
    Don't know if a 6A opto-triac ever exist, never see one in catalog. If one does exist, it is not popular or extremely expensive. So that is why it is out of the question.
    You can, however, use 5V to control a low amperage opto-triac to turn ON/OFF a normal 6A TRIAC.
    Takes a look at the data sheet of opto-triac MOC3020, MOC3021 or MOC30xx....
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    How about a solid state relay? I'm sure you'll get one that will operate off an isolated input in the 3-32V DC range. Power side at 110V AC at 6A should be a "breeze".
  4. eblc1388
    Nov 28, 2008
    1,542
    102
    How much current is needed to trigger the MOC3020?
  5. millwood
    Guest
    a solid state relay would work.
