optocoupler with seperated primary/secondary
Discussion in 'The Projects Forum' started by Orville, Dec 6, 2007.
  1. Orville
    Nov 10, 2007
    Hello, I'm wanting to detect the position of an automatic transmission shift lever to activate a 16 segment single character display. An array of reed switches would serve, but I'm wondering if this could also be done using an opto device with separated primary and secondary, the led to be attached to the shift lever. Is there something available that I might use?
    Orville
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You would probably run into ambient light problems or dirt crudding up the transmitter or receiver. Magnets and reed relays are probably more suited for the application. The magnet will not need wires led to it for power, either.
  3. Orville
    Nov 10, 2007
    Good points, thanks.
    Orville
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
    I'm confused. Optocouplers have primaries and secondaries?
