Optocoupler with breakdown voltage above 50V
Discussion in 'General Electronics Chat' started by cumesoftware, Aug 22, 2011.
  1. cumesoftware
    Thread Starter Senior Member
    Apr 27, 2007
    1,330
    11
    I'm currently looking for a 4-pin optocoupler having a single bipolar phototransistor. The transistor needs to have a breakdown voltage equal or above 50V. I can only find optocouplers with a breakdown voltage of 35V. Is there any type, preferably widely used, that you can recommend?
  2. #12
    Nov 30, 2010
    16,664
    7,311
    Mouser
    512-MOC8021M
    54 cents
  3. praondevou
    Jul 9, 2011
    2,936
    489
    Did you have a look at digikey.pt? There are hundreds of them (Vout > 50V).
    If you post more details like package, forward current, CTR, response time etc. one could narrow the search.
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
    The package I'm looking for is a 4 pin DIP. A forward current of about 50mA or 100mA would suffice. The important thing is the breakdown voltage of the phototransistor that has to be at least 50V or above. I think 40V would do too. The switching doesn't need to be fast.
    Digikey has a lot of parts, but I need to find a general purpose part that can be found anywhere. A part that is most used. This is for a project. Any suggestions?
  5. praondevou
    Jul 9, 2011
    2,936
    489
  6. cumesoftware
    Apr 27, 2007
    1,330
    11
    Thanks for the info!
