My background is in software. I have a solenoid with a coil that operates on 24VDC at no more than 10W so max current is 420mA. I would like to switch it on and off with a micro-controller so bought an mbed(ARM). Digital out is 3.3V when on. I found a "transistor as relay circuit" and read the description on how the transistor worked so I calculated the appropriate resistor values and was proud of myself. The solenoid/coil are about 12 feet from the desired location of the controller. I can see that distance being up to 100 feet. My plan is to have a 24VDC adapter located near the solenoid / coil and 2 wires between them (coil and adapter) and the controller. Although this may never be more than a "hobby" project, I would like to build to commercial specifications.
I e-mailed the schematic to a friend of a friend. He told me that I need an optocoupler, which before yesterday, I had never heard of. Would a 4n25 be a good place to start? Do I need any resistors on the diode side? If so what would be appropriate. In the Fairchild spec there is a graph with 10mA /1.2V somewhere in the middle; is that my target?
I don't really know what to do on the transistor side. I bet a reversed diode would still be used in to protect the transistor from kickback voltage. The original design used and PNP transistor and the 4n25 appears to use a PNP. I clearly need to do more research. Any help would be greatly appreciated.
