optocoupler switch
Discussion in 'General Electronics Chat' started by bioukanon, Jun 6, 2009.
  1. bioukanon
    Jun 6, 2009
    Hello to all. I need a circuit with a optocouple to switch a relay. The input that I need is 12V and the relay is 12V too. I 'll like to use like a simple relay. Do you pls tell me what resistance must choose and what optocoupler is good to make this circuit. Thanks
  2. DC_Kid
    Distinguished Member
    Feb 25, 2008
    641
    9
    here's one (of a milion)
    http://www.fairchildsemi.com/ds/HS/HSR312.pdf
    the resistor needed for opto would be 1050-to-1100ohms.
    you can get 320mA max out of this opto. your relay coil will determine if this is sufficient or not. its also avalanche rated but i would add a diode across the coil to kill the flyback voltage.
