optocoupler (MCT2E) resistor?
Discussion in 'The Projects Forum' started by onlyvinod56, Apr 23, 2014.
  1. onlyvinod56
    Thread Starter Active Member
    Oct 14, 2008
    362
    Hello.
    I need to connect MCT2E optocoupler to F28335 DSP board whose logic high voltage is 3.3V.
    What value of resistor should be used on emitter side?
    Thankyou.
  2. ericgibbs
    Jan 29, 2010
    2,590
    390
    hi,
    The MCT emitter has a forward drop of 1.25V, so I would design for a current of 10mA.
    Thats 3.3 -1.25 = 2.05/.01 =~200R, use a 180R or 220R.
  3. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    ~ 330Ω.
    Max.
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    The "3.3v logic high" sourcing 10mA will be more like 2.8 or 2.9v DC.
    2.8v - 1.25 LED Vf = 1.55v
    R = E/I = 1.55/10 = 155 ohm.
    I would probably go with 180 ohm like Ericgibbs suggested and see how it works.
    The moment you connect it to the logic high pin, you can measure the volts across the resistor because the LED is on and the resistor volts can tell you the LED current; I = E/R = ?/180 ohm
