Why the DAC is not used to drive the optocoupler .
My application is to dimming of AC load using Optocoupler.
Why do you think DACs are not used to drive optocouplers?Why the DAC is not used to drive the optocoupler .
Why not?You have phase shift a AC load pwm will not give a even dimming of power.
The IRLED in the opto isn't linear - a couple of the big name manufacturers have published appnotes for linear opto drive.Why the DAC is not used to drive the optocoupler .
The critical rate of rise of off-state voltage, dv/dt, is measured with the input at 0 V. The frequency of Vin is increased until the phototriac turns on. This frequency is then used to calculate the dv/dt according to the formula: The critical rate of rise of commutating voltage, dv/dt(c), is measured by applying occasional 5-V pulses to the input and increasing the frequency of Vin until the phototriac stays on (latches) after the input pulse has ceased. With no further input pulses, the frequency of Vin is then gradually decreased until the phototriac turns off. The frequency at which turn-off occurs may then be used to calculate the dv/dt(c) according to the formula shown above
by Don Wilcher
by Aaron Carman
by Jake Hertz
