Optocoupler 4n25 relay circuit
Discussion in 'The Projects Forum' started by espanholito, Oct 12, 2010.
  1. espanholito
    Oct 12, 2010
    I hope someone can help me this circuit. I have some 4n25 optocoplers and 2n2222 NPN transistors and I nedd to activate a 24VDC relay coil.
    I have tryed this circuit, but haven´t manage to activate the coil.
    I'm using two computer DC sources connected in series to get the 24VDC.
    Thank you
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Why bother with the opto-coupler? Relays by their very nature are isolated.
    espanholito likes this.
  3. gerty
    Aug 30, 2007
    1,154
    304
    Looks like he only has a 1.5 volt signal, not enough to turn on a relay, or the 4n25 for that matter.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If your input signal is actually only 1.5v, then change R1 to 30 Ohms.
    Remove R2; it'll cause problems.
    Replace R3 with a 2.2k resistor.
    Do you have the emitter of the 2N2222 connected to -12v? You didn't differentiate between collector and emitter (the arrow is missing), but the emitter has to go to -12v in order for it to work.
  5. espanholito
    Oct 12, 2010
    Thank you all very much for your help,
    I forgot to remove the R1 resistor, actually i'm using 1.5V without any resistor connected to pin 1.
    Yes, the emitter is connected to the -12V. I will now test the circuit, after that i'll give my feedback.
    Tonight I have also found a pdf from electus distribution talking about the theory of optocoplers and connection examples.
    I've attached the pdf for everyone who needs it.
  6. espanholito
    Oct 12, 2010
    I have managed to complete the circuit, I attached the final schematic.
    If you see something that can damage the circuit, I would appreciate that you tell me.
    Thank you very much for your support
  7. R!f@@
    Apr 2, 2009
    8,793
    771
    I do not see any reason for the opto. But if u want to use it, u can.
    Use a 30 ohm resistor (R1) in series with signal and opto input or u might burn the opto LED as Sgt suggested
    Second what is the relay coil voltage. If it is not rated for 24V, u will have trouble.
    Third , pin 6 is an input, do not use it, Connect R3 to pin 4.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You do need a current limiting resistor for the input side.
    The datasheet states that the IR emitter has a typical Vf of 1.15v@10mA current.
    You're using a 1.5v signal to turn it on.
    (1.5v - 1.15v) / 10mA = 35 Ohms
    If you omit the resistor, you will probably have excessive current through the IR emitter and it won't last very long.
    As Rifaa mentioned, you have connected R3 to the output transistors' base, which won't work. If you want to connect something to pin 4, make it a 100k resistor that connects to -12v; that will help it turn off more quickly.
