opto isolator question
Discussion in 'General Electronics Chat' started by CaliusOptimus, Dec 8, 2009.
  1. CaliusOptimus
    Aug 14, 2005
    59
    ive never used an opto isolator before, and im thinking it will be the best thing to use for a project im working on.
    my local supply has a few of these on the shelf, and im just curious how to use them. pins 1,2,4 and 5 are no-brainers, but i dont know what to do with the base connection.
    say i wanted to use the transistor to control a cmos gate....i would tie the emmiter to gnd, and a 1k resistor between Vdd and the collector. what do i do with the base pin?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You just leave the base open. You will find that a larger pullup will work better, as the 1K value will probably not let the transistor go to 0 volts. See if 47 K doesn't work better.
  3. BMorse
    Sep 26, 2009
    2,675
    234
  4. CaliusOptimus
    Aug 14, 2005
    59
    cool! thanks guys, much appreciated.
