opto coupler
Discussion in 'General Electronics Chat' started by z3ngew, Apr 19, 2013.
  1. z3ngew
    Apr 18, 2013
    13
    Hello everyone,
    I need to know, when i use the optocoupler (npn) i give a signal to the diode throw a resistor, and the transistor is switched on.
    ok, that's great but the question is can i connect the emitter to vcc and the collector to the output, maybe the base of another transistor.
    Thanks in advance,
    z3ngew
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Just to be sure can you make simple schematic/drawing of what you plan to do :)
  3. Just_starting
    Sep 25, 2012
    5
    Simply yes. You can connect ground or VCC to one side of the output and use the other side as a signal so effectively creating an inverting or non-inverting, voltage independent line protector. I use this regularly.
  4. ScottWang
    Aug 23, 2012
    4,936
    777
    You adding a reverse voltage to the transistor, it could be damaged the transistor.
    For a NPN transistor of the optocoupler:
    Usually we adding the +Vcc to C and connecting a resistor from E to Ground, and the E will be the output.
    You can also connecting a resistor from +Vcc to C, and the E connected to Ground, and the C will be the output.
