Opto Coupler for Parallel Stepper Motor ...
Discussion in 'The Projects Forum' started by rockyman33, Jul 13, 2009.
  1. rockyman33
    Jul 5, 2009
    I have a opto coupler (4n25x) that I want to use to isolate my PC from a stepper motor driver and controller and I can't seem to make the LED side have any effect on the transistor side.
    I'm using a power supply I put together from a old pc, and I'm wondering if the volts or amps have anything to do with my problem.
    I'm kinda new at this stuff, obviously. I'm not exactly sure the best way to utilize the transistor side. I know there a number of ways to do it.
    Some direction would be great.
    parallel is about 3.7 to 5v, for the led, and I want to make the driven transistor 12v.
    Rocky
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Are you able to post schematics of the circuits you have built?
  3. rockyman33
    Jul 5, 2009
    why 15k resistor? how do you know?
    Thanks for your help.
  4. rockyman33
    Jul 5, 2009
    how do you post schematics? is there a utility in this website?
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    There are provisions for attaching images, preferably in .PNG format.
    Click the "Go Advanced" button below the reply text box.
    Then click the "Manage Attachment" button under "Additional Options" under the reply box.
    Navigate to where the image is stored on your hard drive, and select it, then click the Upload button.
  6. rockyman33
    Jul 5, 2009
    Thanks sarge, your alot of help. nice suit.
