Optimum temperature of condenser coil refrigerant
Discussion in 'General Science' started by sheepdog, Jan 26, 2009.
  1. sheepdog
    Jan 26, 2009
    8
    Hi could anybody tell me the above please, for the refrigerant leaving the condenser coil of a heat pump/air con unit. I am building a prototype heat pump and wish to pwm the condenser fan with a mcu to ensure the temperature is in the right ball park before entering the expansion valve/capillary tube.
    Any help/advice greatfully appreciated
    Many thanks
    oscar
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    I don't know the answer, but I suspect you will need to know the refrigerant type to find out its thermodynamic properties.
    John
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The refrigerant cycle involves moving heat, so it becomes more efficient as the end points are further separated. For cooling, you really wish to remove all the heat of compression possible before expanding the fluid to pick up heat. In heating, you wish to transfer all the outside heat possible into the refrigerant before compressing it.
    The idea is to shorten cycle times, as it takes the same energy to compress the refrigerant per unit of time.
  4. sheepdog
    Jan 26, 2009
    8
    Many thanks for the replies, the unit I am modifying is some 10 years old, refrigerant of unknown type. At present I am achieving a 3 degree c drop from a 7 degree source through a homemade heat exchanger. i will try reducing the condenser exhaust (fan only at the moment) via the incoming source and experiment further.
    Again thank you for your information
