Optical Sensor (Time to decode - TTD)
Discussion in 'The Projects Forum' started by bc627, May 20, 2013.
  1. bc627
    May 20, 2013
    6
    i am working on a school project and need to design a circuit that will decode the time it takes once a light is triggered to the time it goes off (time to decode - TTD).. i have some ideas but i am somewhat of a newbie.. any help would be greatly appreciated.. -thank guys
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    We can help but you will have to explain a bit more clearly what you are attempting to do.
    What do you mean by "light is triggered to the time it goes off"?
    What level school work is this?
  3. bc627
    May 20, 2013
    6
    this is for my engineering class (undergrad)
    we will be triggering a device that sets off a light that will remain on for a variable amount of time from 0-10sec (measuring only ms and sec)
    We would like to count the time it takes once it is triggerd to the time it cuts off ex: light on - light off = .143ms
    We are goin to implement a microcontroller and a light sensor and send the information via usb to our laptop
  4. MrChips
    Oct 2, 2009
    12,624
    3,451
    What turns off the light?
  5. bc627
    May 20, 2013
    6
    its an external trigger which has already been configured
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    Use a photosensor and measure the duration that the sensor receives light.
  7. bc627
    May 20, 2013
    6
    ive had a few ideas, but not sure if theyd work.. 2 photo transistors.. maybe an LDR so the counter starts when light is on so the resistance drops using an opamp to bias transistor to relay
  8. bc627
    May 20, 2013
    6
    any ideas on how to design the circuit so it functions properly?
  9. MrChips
    Oct 2, 2009
    12,624
    3,451
    What relay? I thought you just wanted to measure the time the light is on.
    Connect the output of the photosensor to an input pin of the microcontroller.
  10. bc627
    May 20, 2013
    6
    more or less yea... i just want to trigger the light, initiate timer.. light goes off.. stop timer.. send data to computer.. it just seems like there would be more to it then just that.. u made is sound so simple
  11. wayneh
    Sep 9, 2010
    12,374
    3,226
    If you want complicated ... try here.
  12. LDC3
    Apr 27, 2013
    920
    160
    I think the calculation delay might be toooooo long. :D
  13. LDC3
    Apr 27, 2013
    920
    160
    The microcontroller is the timer, so you don't need a separate timer.
