optical modulator (optical modulations )?
Discussion in 'General Electronics Chat' started by abhimanyu143, Feb 12, 2015.
  1. abhimanyu143
    Aug 25, 2014
    211
    hello ,
    modulation is process by which some Characteristic of carrier wave (amplitude , frequency phase) varied according to modulating signal. this process called modulations
    carrier signal - EM wave
    modulating signal - image , music, speech signal
    what is optical modulator ? what is optical modulations ?
  2. pwdixon
    Member
    Oct 11, 2012
    488
    56
    ask google.......
  3. abhimanyu143
    Aug 25, 2014
    211
    ok according to my search ''modulation is process by which some Characteristic of optical carrier wave (amplitude , frequency phase) varied according to modulating signal. this process called optical modulations. I am not sure
  4. shortbus
    Sep 30, 2009
    4,095
    1,684
    Some Fender guitar amplifiers used this for a "reverb" in them. Basically a neon light bulb and a photo transistor bound together to make the modulation. There was a recent tread over at ETO forum about them.
  5. Magician
    Aug 18, 2014
    13
    6
    Optical modulation has one more, polarization. You can modulate polarization of the laser beam, and measure a sugar level.
  6. crutschow
    Mar 14, 2008
    13,498
    3,374
    By optical modulation, do you mean modulating a light beam?
    What are you trying to do?
  7. GopherT
    Nov 23, 2012
    6,310
    4,031
    The same concepts with electricity can be used to modulate light to send information. Fiber optics is one example. You can also encode audio signals into a pwm signal and send it as IR light to a receiver that filters out the pwm frequency and passes the audio portion. It can then be amplified and listened to. The old Mimms books have several encoding methods listed for LEDs. PWM is just one example.
  8. shortbus
    Sep 30, 2009
    4,095
    1,684
