Optical isolator (optical switch)
Discussion in 'Homework Help' started by skiddman, Apr 15, 2013.
  1. skiddman
    Nov 7, 2012
    I need some help with an optical isolator specifically what is the operation of an optical isolator referring to the transmitting side and detecting side and the state of these devices with respect to the light.
  2. t06afre
    May 11, 2009
    Tell which opto isolator you use. Then draw a simple drawing of how you plan to connect it. Then we can help. Use the part number to search for the datasheet. That will give valuable information
