Opposing electrical magnets
Discussion in 'General Electronics Chat' started by Gdrumm, Aug 2, 2014.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    Can electrical magnets be made to oppose each other the way earth magnets do?
    Gary
  2. tom_s
    Member
    Jun 27, 2014
    287
    342
    i would assume the answer is yes, my understanding - reversing the current flow would change the polarity.
  3. Alberto
    Nov 7, 2008
    169
    36
    When your coil is powered it will produce a magnetic field with north in front and south on the back ( depending on polarity if DC if AC you will have N and S changing at the AC frequency)
    Alberto
  4. studiot
    Nov 9, 2007
    5,005
    515
    An electromagnet has north and south poles in just the same way as a permanent magnet.
    A linear solenoid generates the same field configuration as a bar magnet.
    The direction is given by the right hand screw rule, with the North at the point of the screw as shown in the second part of the sketch on the right.
    Gdrumm likes this.
  5. ErnieM
    Apr 24, 2011
    7,439
    1,627
    Of course they can. A magnet is a magnet is a magnet.
  6. shortbus
    Sep 30, 2009
    4,096
    1,692
    That's how a "wound field" electric motor works.
  7. wayneh
    Sep 9, 2010
    12,391
    3,246
    An electromagnet in a black box can not be differentiated from a permanent magnet in a black box. As Ernie noted, a magnet is a magnet.
  8. Gdrumm
    Aug 29, 2008
    684
    36
    What would be the determining factors regarding how much of a gap I could achieve between the magnets, when they are opposing; more voltage, more core wire?
    I'm thinking of an application where a machine, when in set up mode, would have two electrical magnets opposing each other, creating a gap (of about 1/8") through which I could thread a substrate.
    Then, when switched to the run mode, the magnets would come together, grabbing the substrate, then by mechanical assist, feed the substrate into a die, to be cut.
    The unit already exists, and has an electromaget that feeds the material into the die.
    The bottom portion is the electrical magnet, the top portion is simply a steel plate.
    But I'm looking for a way to thread the material into the magnet area during set up, that does not involve touching the magnet carriage mechanism with human hands.
    If I can aviod touching the carriage mechanism during set-up, I can avoid having to lock out the machine, for OSHA concerns.
    I've tried a simple spring attached to the top portion, and it does create some seperation, when the magnet is off, but not enough to do what I need to do.
    If I increase the spring pressure, then when the unit is turned back on, it is not powerful enough to overcome the spring, and re-engage the substrate.
    Thanks,
    Gary
  9. wayneh
    Sep 9, 2010
    12,391
    3,246
    I don't see why that would not work.
    Is it conceivable to replace the steel plate with a permanent magnet? Then all you'd have to do is reverse the current in the existing electromagnet and it would go from attraction to repulsion. A negative, from a safety point of view, is that there would still be attraction with all power off.
    Another approach would be to simply replicate the existing electromagnet and replace the steel plate, but you probably don't need as much field strength as this would enable. The 2nd magnet can probably be a much lower field strength.
    Field strength is proportional to amp-turns. The usual challenge is to choose which wire gauge to wind so that, in the volume you have to place the coil, you get a reasonable compromise of DC resistance and turns; both go up with wire gauge and length. Of course current - and thus field strength - goes down with DC resistance. Heat dissipation is another concern.
  10. studiot
    Nov 9, 2007
    5,005
    515
    To a first approximation you can adapt the formula, which is used to calculate the lifting capacity of lifting electromagnets.
    P = \frac{{{B^2}A}}{2{\mu}}
    Where B is the field induced by a single electromagnet by current I.
    A is the cross sectional area of the facing steel areas.
    P is the force developed between the faces.
  11. Gdrumm
    Aug 29, 2008
    684
    36
    Replacing the steel plate with a permenant magnet in this case would create a problem. There must be a release between the two during the return stroke, otherwise it would pull the paper (substrate) back out of the die.
    I will sleep on it.
    It might be best to try to make one, and see how much seperation I get, using parts I have in stock.
    It might be a Rube Goldburg too!
    Thanks,
    Gary
