I cant figure out how to find the differential output voltage of a differential amp. the problem gives me collector resistor and current values. Can you help?
maybe, posting a circuit diagram would be a good startI cant figure out how to find the differential output voltage of a differential amp. the problem gives me collector resistor and current values. Can you help?
Fully differential op-amps do.An opamp doesn't have a differential output.
by Aaron Carman
by Don Wilcher
by Aaron Carman
