operational amplifiers
Discussion in 'Homework Help' started by Geney, Oct 9, 2012.
  1. Geney
    Apr 2, 2012
    18
    What do the :terms GB and EA in an op amp mean?
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    I suppose GB is gain-bandwith.
    Don't know what is EA.
    Can you post the data sheet, text or context?
  3. Geney
    Apr 2, 2012
    18
    Actually vwe used an op amp as an integrator and in the circuit I came across these terms. A voltage dependent current source is named as gb and voltage dependabt voltage wad referred as ea in the circuit
  4. Ron H
    Apr 14, 2005
    7,050
    657
    In spice simulators, g is the designator prefix for voltage-dependent current sources, and e is the designator prefix for voltage-dependent voltage sources.
  5. WBahn
    Mar 31, 2012
    18,085
    4,917
    It would be a great help if you could provide a sketch of the circuit you are talking about so that we have some context and don't have to play mind-reader.
