Operational Amplifier
Discussion in 'Homework Help' started by ds_164, Nov 8, 2004.
  1. ds_164
    Nov 6, 2004
    Hi, I got the following problem for homework (attached), I solved it but wanted to double check the answer.
    Please give it a try. Thanks.
    [attachmentid=226]
  2. vineethbs
    Nov 14, 2004
    56
    i think the noninverting input is A
    apply a + vol to A and B grnd
    as it is pnp the collector current prop to exp(vbe/vt) decreases say by dI
    I biasing so , current thru B inc by dI
    3A current source so current thru o/p trans of the second stage decreases by dI
    VB-Vbe=constant at emitter of the o/p transistor of the second trans
    so as current decreases Vce increases and o/p amp gain = +1 so o/p increases
    + at A => + at o/p
    so A is non inverting
