Operational amplifier
Discussion in 'Homework Help' started by regexp, Dec 28, 2010.
  1. regexp
    Nov 20, 2010
    24
    I have the following operational amplifier:
    My task is to calculate the expression that yields the quotient ~~\frac{u_0}{i_s}
    Hm, i don't really know how to start, any advice?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Consider the features of an ideal opamp.
    1. Infinite open loop gain.
    2. Infinite input impedance on both input terminals
    3. Output impedance is 0 ohms.
    Also consider that an opamp's mission is to drives its output to whatever voltage it takes to make the two input terminals equal in voltage. In this opamp configuration, the positive terminal is at 0v. That means that the opamp is going to drive its output to a voltage that will force its negative terminal to be 0V.
    hgmjr
  3. shteii01
    Feb 19, 2010
    3,518
    515
    \frac{U_0}{I_s}=R_3(\frac{R_1}{R_2}+\frac{R_1}{R_3}-1)
    Can someone check me?
  4. Ron H
    Apr 14, 2005
    7,050
    657
    That's not correct.
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    Think about it as "What current will flow through R3?"
    Since R1 and R2 are voltage dividers across the current source, and R3 is the tap to the output.....
  6. shteii01
    Feb 19, 2010
    3,518
    515
    Ok. So. There is no current in R3? Then U0=R2(Is)?
  7. Ron H
    Apr 14, 2005
    7,050
    657
    No one said there is no current in R3. How did you conclude that?
  8. shteii01
    Feb 19, 2010
    3,518
    515
    I am just stumbling in the dark. When I solved it the first time, I thought R2 and R3 would act as current divider, that was shut down. Now I am out of ideas.
  9. Jony130
    Feb 17, 2009
    3,993
    1,116
    Here's a tip:
    You can convert the T-pad network to a PI-pad network using the Y-Δ transformation:
    http://en.wikipedia.org/wiki/Wye-delta
    Or you could just write out your node equations
    Is = ( Va - Vb) /R1 (1)
    Is = Vb/R2 + (Vb - Vout)/R3 (2)
    Va = 0V ( thanks to op amp "action" )
  10. Ron H
    Apr 14, 2005
    7,050
    657
    Are you the same person as regexp?
  11. hgmjr
    Jan 28, 2005
    9,030
    214
    Greetings Shteii01,
    Like RonH, I too am confused. Your replies are phrased in such a manner that it sounds like you are the originator of this thread.
    Can you please confirm that you "are" or "are not" regexp?
    hgmjr
  12. shteii01
    Feb 19, 2010
    3,518
    515
    This is not my thread. I am trying to solve it because I am not very good at op-amp circuits, I thought it would be good practice for me. Note that I only posted my answers, I still want regex do his own homework.
  13. shteii01
    Feb 19, 2010
    3,518
    515
    I see what you mean. I think I can do node equations on the original circuit.
    Ok, I redid the problem using node voltage method on the original circuit. I got following: \frac{U_0}{I_s}=-R_3(\frac{R_1}{R_2}+\frac{R_1}{R_3}+1)
  14. Jony130
    Feb 17, 2009
    3,993
    1,116
    Your equation look good for me
  15. Ron H
    Apr 14, 2005
    7,050
    657
    Yeah, that's what I got too.
  16. BillO
    Distinguished Member
    Nov 24, 2008
    985
    136
    The minus sign looks wrong. Everything else looks right.
  17. hgmjr
    Jan 28, 2005
    9,030
    214
    I obtained the same answer as shteii01 using Millman's Theorem.
    hgmjr
  18. Ron H
    Apr 14, 2005
    7,050
    657
    The output voltage is bound to be negative, due to the direction of the current and the feedback.
  19. BillO
    Nov 24, 2008
    985
    136
    Hmm, suit your self, but there are valid ways to work this out so that you do not end up with negaitve ohms as your answer.
  20. Ron H
    Apr 14, 2005
    7,050
    657
    Put your money where your mouth is.:D
