Operational amplifier Jitter
Discussion in 'General Electronics Chat' started by Kaspars, Jun 20, 2011.
  1. Kaspars
    Jun 9, 2011
    17
    Can someone suggest me real Operational amplifier with as small as possible Jitter?
    My OP works in comparator mode and I need low jitter Operational Amplifier so the edge deviation would be as small as possible.
    Thnaks :)
  2. Ron H
    Apr 14, 2005
    7,050
    657
    Op amps make inferior comparators. You will get lower jitter from a real high speed comparator.
    What is your application?
  3. Jaguarjoe
    Apr 7, 2010
    770
    90
    Are you saying you get jitter when the output switches from one state to the other? If so, you need a hysteresis resistor added between the output and the (+) input. Usually, it's a high value, like 100k.
    Because of their internal compensating capacitor op-amp comparators are very slow. An LM339 is a very common comparator chip. Beware that it has an open collector output requiring an external pull up resistor. Also note that its output current capacity is low.
  4. Kaspars
    Jun 9, 2011
    17
    My application is Asynchronous Sigma Delta modulator with hysteresis:
    Where I use AD8056 operation amplifiers with slew rate 1400V/us.
    So I want jitter effect as small as it could be, becouse ASDM resolution depends on switch time accuracy.
  5. Jaguarjoe
    Apr 7, 2010
    770
    90
  6. Ron H
    Apr 14, 2005
    7,050
    657
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
