Operating a relay with a PIR sensor
Discussion in 'The Projects Forum' started by allenpitts, Feb 21, 2015.
  1. allenpitts
    Thread Starter Active Member
    Feb 26, 2011
    77
    7
    Hello Electronics forum,
    I have got the PIR sensor circuit to work
    Now need to get the sensor to work a relay to close a circuit
    that turns on an MP3 player.
    Made sure that the out put of the sensor
    http://www.adafruit.com/product/189
    at 3.3 v matches the relay which is a 3V
    relay
    But it wont latch the relay.
    Any ideas why the signal from the PIR sensor
    won't operate the relay?
    Thanks.
    Allen in Dallas
  2. Reloadron
    Jan 15, 2015
    1,041
    268
    Remove the LED and 220 Ohm resistor. The LED and resistor are dropping the voltage so the relay coil never sees 3 volts. Then we can go from there if the relay works. Also, make sure the PIR can source the needed relay current. Do you have a data sheet for the PIR and relay?
    Ron
  3. Reloadron
    Jan 15, 2015
    1,041
    268
    The data sheet for the relay with the 3 volt coil calls out 50mA. I found that. I am not sure how much current the PIR sensor module can source? They do mention the PIR sensor should be powered by 5 volts but does work on 3 volts but for 3 volt supply operation you need to bypass the 3 volt regulator on the little circuit card. Did you do that since you seem to be powering the PIR off 3 volts?
    Finally if the PIR can't source the 50 mA for the relay and the LED current what you will need to do is place the relay and LED in a parallel configuration and power them using a transistor driven by the PIR. That would be my guess anyway. It won't work as drawn, I can tell you that much.
    Ron
  4. Pencil
    Dec 8, 2009
    271
    38
    +1 to Reloadron's replies.
    Relay Datasheet
    Decoder I.C. Datasheet
    Can't tell if there is any drive circuitry on the board. If not, looks like 10mA is output source current.
    Attached a schematic with transistor to try. Do not omit protection diode around relay coil.
  5. Reloadron
    Jan 15, 2015
    1,041
    268
    I would do it like Pencil's drawing with one change.
    Pencil, since we have a 2N2222 in there I would just let the transistor also drive the LED in parallel with the relay. I am guessing maybe 15mA on that LED? I would put the LED up there with the relay on the collector. I should have mentioned the need for the flyback diode too. :)
    Ron
  6. Pencil
    Dec 8, 2009
    271
    38
    Feature creep. I was adding to the original without consideration for best design practice.:)
    Re-spun drawing as Rev 2.
    P.S. Relay current requirements will cause terrible battery life.
  7. Reloadron
    Jan 15, 2015
    1,041
    268
    Great, that will work just fine.
    Allenpitts, do it just like Pencil's circuit.
    Ron
  8. allenpitts
    Feb 26, 2011
    77
    7
    Hello Pencil and Relaodron,
    I got it to work! Thanks. I have been working on this
    for weeks. I should have used the multimeter to
    troubleshoot. When the multimeter was connected
    between the LED and the resistor and then to ground
    (in my circuit) the reading was 1.77 volts. Not enough to latch the
    relay.
    Used your excellent shematic and it works like a champ.
    The yellow LED on the right comes on when the relay switch closes. The red LED is between the collector
    and the 220 resistor as shown on Pencil's schematic.
    The next step is to make the relay turn on an LED sequence display. When that works will post it to this
    thread. Then after that will use this circuit to turn on an MP3 player on an Arduino.
    Also plan to take this circuit and move it from the bread board to an Archer 276-159
    http://www.radioshack.com/dual-general-purpose-ic-pc-board/2760159.html#.VOpTAe8tHIU
    Thanks again. I am still learning electronics but I have some skills with web development,
    schematics drawing and Fritzing. If I can ever reciprocate the favor by being of service in
    one of those endeavors I am and will remain
    Your humble servant,
    Allen Pitts, Dallas Texas
  9. Brownout
    Jan 10, 2012
    2,375
    998
    Now you need a timer to keep the MP3 playing for a prescribed time after the PIR is triggered.
  10. allenpitts
    Feb 26, 2011
    77
    7
    Hello Circuits Forum,
    Couldn't get to my soldering iron today but could get to the drawing tool.
    First I did a pictorial of the breadboard. I am pretty sure this one is good
    although I will prove it this week end.
    Thinking of getting off the breadboard for a more permanent solution
    using my old friend the Archer 276-159. Not as sure on this one but
    will test this weekend and advise. But if you can see any flaws your
    input is appreciated.
    Both of these are based on Pencil's design and Relaodron's feedback.
    Thanks.
    Allen in Dallas
  11. Reloadron
    Jan 15, 2015
    1,041
    268
    At a glance it looks OK to me but I am not as good with the eyes and following things as I once was. With the demise of Radio Shack I will miss those little boards. :)
    Ron
  12. djsfantasi
    Apr 11, 2010
    2,900
    874
    Why not connect the PIR sensor directly to the Arduino, and use it to turn on the MP3 player instead of a relay. Since the MP3 player is part of the Arduino. Is it an Arduino or ADAFruit shield (I use the ADAFruit Music Maker MP3 shield)?
  13. ScottWang
    Aug 23, 2012
    4,925
    777
    I'm not sure how much current the PIR can output, but I'm afraid the R2 is too small and it will draw too much current.
  14. Pencil
    Dec 8, 2009
    271
    38
    Allen,
    You stated your relay has a 3V coil. Your circuit, using a 9V battery, is going to damage the relay.
    I mistakenly thought you could power it from 4.5V (3 1.5V cells), my mistake, I was looking at the voltage range for
    the decoder I.C.
    One solution is to get a relay with a 9V coil and re-calculate the resistor values for the LEDs and base of the transistor.
    I believe using a 9V alkaline cell is going to give poor battery life compared to other cells such as AA, C or D. See chart linked below, compare mAh capacities to see what I mean.
    Battery Capacity Chart
    As I stated earlier, use of a relay will cause poor battery life, maybe consider the use of rechargeable batteries.
    You have a nice project, before committing to a board maybe review the power source to insure the best outcome.
    Post any questions.
  15. Pencil
    Dec 8, 2009
    271
    38
    It was 3.3V output, speculated to be 10mA, per datasheets on board and decoder chip thought to be on the board.
    djsfantasi likes this.
  16. ScottWang
    Aug 23, 2012
    4,925
    777
    The low side(-) of relay was wrong on the breadboard, but the pcb layout was right.
  17. allenpitts
    Feb 26, 2011
    77
    7
    Hello Forum,
    ReloadRon: Yse the RadioShack bankruptcy and store closings really bums me out. Not only becuase it is headquartered in Fort worth which is sister city to my native Dallas but also because it is right
    down the road from me and now I have to travel to Fry's to get components. I did find a knock off
    of the Archer 276-159B
    http://www.mcmelectronics.com/product/21-4595
    and maybe an improvement to it at
    http://www.mcmelectronics.com/produ...il&utm_medium=email&utm_campaign=ConfirmEmail
    Disfantasi: Will ditch the relly when I get to the Arduino but am having trouble with a sketch which simply
    plays the same MP3 track over and over when triggered by the PIR sensor. But that is the subject of another thres probably oj a different forum.
    Scott Wang: Not sure how the relay can have a wrong side since it is just a switch and does not have polarity.
    Will reduce the voltage of the supply and change the relay load to a LED display this weekend and advise.
    Allen in Dallas
  18. allenpitts
    Feb 26, 2011
    77
    7
    It is a a SparkFun MP3 Player Shield
    https://www.sparkfun.com/products/10628
    Having a hard time getting it to work.
    The sketch is hundreds of lines long.
    All I want it to do is play one track when
    the PIR sensor fires.
    Thanks.
    Allen in Dallas
  19. djsfantasi
    Apr 11, 2010
    2,900
    874
    Are you using the library? I am not familiar with the Sparkfun product, but do use the Adafruit MP3 shield. With the library and its example sketches, I was able to play a track on an event in less than 100 lines of code.
    Can you attach your sketch? I'd like a chance to look at it. Tonight, I'll upload my example, if you'd like.
  20. allenpitts
    Feb 26, 2011
    77
    7
    Hello DJ,
    I like Adafruit and am using their PIR Sensor becuase it has sensitivity and timer trim pots
    that the Parallax, SparkFun and Radio Shack Sensors do not.
    But would like to use the SparkFun MP3 Shiels because I already bought it but
    more importantly it sits right on top of the Arduino Uno so I don't have to have another
    breadboard or prototype PCB.
    But if I can't get it to work its useless and I will have to start all over with Adafruit.
    Here's the sketch
    +++++++++++++++++++++begin sketch+++++++++++++++++++++
    #include <SPI.h>
    #include <SdFat.h>
    #include <SdFatUtil.h>
    #include <SFEMP3Shield.h>
    SdFat sd; //create an instance of SdFat named sd
    SFEMP3Shield MP3player; //create an instance of SFEMP3Shield named MP3player
    int triggerPin = ??; //this sets the pin the PIR will use
    boolean triggerState = false; //this variable indicates if detection is in progress
    void setup() {
    //start the shield
    sd.begin(SD_SEL, SPI_HALF_SPEED);
    MP3player.begin();
    //you also need to set the input pin to be an input
    //this was missing from your code
    pinMode(triggerPin, INPUT);
    void loop() {
    //if trigger pin reads HIGH then PIR is detecting
    if (digitalRead(triggerPin) == HIGH) //see how this is different from your code
    if (triggerState == false) //only play track if not already played this detection
    triggerState = true; //set triggerState, reset only after triggerPin goes LOW
    MP3player.playTrack(1); //play track 1, will only happen once per detection
    } else {
    if (MP3player.isPlaying() == false) //triggerPin must have been LOW to get here
    triggerState = false; //track must be done playing to get here, re-enable track
    // no need to stop the player after 6 secs, it'll stop on it's own
    +++++++++++++++++++++end sketch+++++++++++++++++++++
    Allen in Dallas
