That core looks like it is soldered/welded together?
This transformer looks rather small so it's difficult to tell. Lots of the larger transformers like street light ballasts are welded and I've cut through the weld with a disc grinder, then rewelded it back together. Salvaged the 120 volt coil(s) added a secondary for a fairly large capacity battery charger.Looks Tig welded.
Are those glue stuff safe? I mean not poisonous? I don't have a spare microwave oven.I use a microwave oven & it works realy well & doesnt melt the plastic bobbin. The oven i use is an old one specificly for this purpose, as its hard on the magnetrons. Have replaced acouple of magnetrons for about 30 transformers. Magnetrons are free from other dumped microwave ovens which had other problems. I have a large supply of magnetrons from the local scrap yard.
Not welded together, I can cut some off with a utility knife easily, I just can't cut through it.That core looks like it is soldered/welded together?
by Aaron Carman
by Jake Hertz
by Jake Hertz
