open port no 25
Discussion in 'Computing and Networks' started by chandrasekhar, Nov 12, 2010.
  1. chandrasekhar
    Nov 5, 2010
    13
    :eek:
    while using telnet to send email;there came response ;couldn't open connection to host,on port 25:connect failed.
    can anyone solve this problem.:rolleyes:
  2. Potato Pudding
    Jun 11, 2010
    684
    92
    Not sure if it relates but Telnet uses port 23.
    Or I think port 995 for VPN.
  3. Potato Pudding
    Jun 11, 2010
    684
    92
    And Telnet is not an Email protocol.
  4. AlexR
    Jan 16, 2008
    735
    54
    Telnet does indeed use port 23 but I expect you are using telnet to connect to a host then using sendmail on that host to email the remote computer.
    Port 25 is the sendmail smtp port so the error message is saying that the computer that you are connected to via telnet can't connect to the remote host sendmail port. This could either be a firewall issue or possibly smtp is not configured on the host that you are trying to email. In either case you should be speaking to your system administrator.
    chandrasekhar likes this.
  5. retched
    Dec 5, 2009
    5,201
    313
    Your ISP may block port 25.
    If there has been problems with spammers using it, it has likely been blocked.
    You WILL HAVE TO USE another port, or call your ISP to see if they will unlock port 25 for you. Some will. Most will not.
  6. chandrasekhar
    Nov 5, 2010
    13
    is there any way by which smtp can be configured on the host.
  7. retched
    Dec 5, 2009
    5,201
    313
