Open Loop Gain
Discussion in 'General Electronics Chat' started by xn47, Jun 13, 2007.
  1. xn47
    May 22, 2007
    22
    Do you have any easier approach on how to solve the open loop gain of OP-AMP (741 in particular)?
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    An easier approach than what method?
    Dave
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The spec sheet on the device gives the open loop gain. Let the fab house do the work.
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
    Perhaps, negative feedback. Hence we have a closed loop gain, substancially smaller than the open loop gain (since open loop gain is the gain of the op-amp as it is).
    But I'm in the dark here, since I'm not sure if you want to decrease gain (what do you mean by "solving the open loop gain"?).
  5. xn47
    May 22, 2007
    22
    than small signal analysis
  6. Ron H
    Apr 14, 2005
    7,050
    657
    Do you want to measure open loop gain with test equipment?
  7. xn47
    May 22, 2007
    22
    by computation. Actually I have finished discussing that topic with my group. Right now, I am currently hooked in computing common mode gain of differential amp using bisection theorem. where; Acm = (-gmRc)/[(1+2gm.REE)(1+1/Beta)]
    hmm.. hows that? If its not too much to ask..
  8. xn47
    May 22, 2007
    22
    I have here an attachment of half ckt wherein I transform its current source to its Norton equivalent ckt.. where REE is shunted to the source. How will you get Common mode gain as I state in my last reply..
    Thanks..
  9. Ron H
    Apr 14, 2005
    7,050
    657
    I'm not sure that's relevant to a 741. It does not take the output off one collector. It has a current mirror on the output of the differential input stage. The common mode gain is really only a function of how well balanced the current mirror is.
  10. xn47
    May 22, 2007
    22
    Thanks.. this is another case..
  11. Distort10n
    Dec 25, 2006
    429
    Although I am not sure, I would imagine manufacturers use a Venable and sweep across the frequency spectrum to measure open loop gain. The result would be the Bode plot in the datasheet.
    I have no idea what the test set up would be.
