Open loop gain Op-amp?
Discussion in 'General Electronics Chat' started by dtvonly, Feb 19, 2013.
  1. dtvonly
    Dec 14, 2012
    43
    Hi. what is the function of the attached circuit? I would think that the op-amp is configured as a open-loop gain amplifier. Therefore, the output will always be Vcc or +15V (ideally). Is this correct? Thank you.
  2. crutschow
    Mar 14, 2008
    13,501
    3,375
    Yes, the output capacitor means there is no DC feedback and thus the op amp will go to the positive rail for any positive input.
    dtvonly likes this.
  3. Jaguarjoe
    Apr 7, 2010
    770
    90
    Isn't that an integrator of sorts?
  4. dtvonly
    Dec 14, 2012
    43
    at first glance, it may appeared as a integerator configuration. If it is an integrator, then I have not seen it in this form before. In fact, I had searched the web but nothing (in this form) came up. So why use it at all if its output will just be from rail-to-rail no matter what? This is a real circuit that a hardware engineer at my company is using in his power supply design. I am a firmware/software developer who used to be in hardware. I guess I am just getting rusty at H/W now.
  5. JMac3108
    Aug 16, 2010
    349
    66
    The circuit has infinite DC gain but the gain rolls off at higher frequencies as the capacitor impedance is reduced. At a high enough frequency the gain is 1+ (1k/10k) = 1.1.
    Normally you would have a resistor in parallel with the cap to limit the DC gain.
  6. crutschow
    Mar 14, 2008
    13,501
    3,375
    That circuit would work only if it is part of a feedback loop with DC feedback.
  7. bountyhunter
    Sep 7, 2009
    2,498
    507
    Looks like a comparator with some AC rolloff?
  8. crutschow
    Mar 14, 2008
    13,501
    3,375
    What would be the purpose of a comparator with AC rolloff? :confused:
  9. t06afre
    May 11, 2009
    5,939
    1,222
    Academic exercise I think
    :rolleyes:
